Not sure....going to rip into it tonight. I will measure them first thing in the AM at work and then I can go from there.
i'd measure what the IFR is first; probably .036"-.038". I did notice in an older QF catalog a Q850 with .070" IAB's, but seen a 850-2 with .073" IAB. sometimes the dash numbers indicates a revision. .073" would be an easier change if you have them. I thought you might have been running a bigger cam than that. what type of ignition? my internet is out at home so reply's may not be too timely.
Try 0.035 to 0.40 for the idle restrictors or smaller if needed. Also do you have restrictors installed for the t-slots? It may or may not need them.
How big are your holes in the plates? I like no transfer slot showing on the rear and very little on the primary. Ideally you should move the IFR to the low position. Probably low to mid .30’s. IAB is close. .070-.073 is where it’ll probably want to be. The PV size has no effect on the idle. Float level and fuel pressure are also important. Holley’s only need 5-6#
I would try downsizing the IFR's a couple of sizes first. I have had better luck with changing idle A/F with the IFR's than the IAB's. IAB's seem to affect everything whereas IAB's concentrate on just idle.
One hole in each blade 3/32". Transfers were almost nil in primary and small in secondary. I figured the opposite to limit fuel pulled in by the primary circuit. I shall re-eval that. The jets need to stay up top with this metering block as I cannot thread the bottom hole. No provisions or space that I can see. I was thinking of maybe going to a .034 IFR (2 sizes down) and then if need be going to a 72 IAB to fine tune if its real close? Or should I try and drop down to a .033 which is 3 sizes?
Try .033. I feel like there is something else going on if it’s that rich. How are you adjusting the screws?
If they're 0.034 then make a huge change that way you will know you're on the right track. Try 0.025 and see what happens.
2 or 3. Enough to notice a difference. Stick your 33's in and see what happens. Curious if something else isn't going on like stated above also. I always read that the butterflies dont need to be drilled until you have a fairly radical motor?How many sizes did you drop at once. This thing is pig rich man....Like light fuel smoke coming out pipes at idle and burn your eyes!
I never use a vac gauge to set idle. Reset your transfer slots. reduce the IFR.s. Open the idle screws up a bit and start it up. Slowly turn one in until the idle starts to fall off. Back out half turn. Work your way around the carb doing the same thing to all corners.
Have you considered drilling your own bleeds?You would need the proper drill set,but when you need one that you don't have..........I have 2 carbs so it doubles the fun.You can open a bleed but you can't make it smaller!
the thing needs more air. .036" isn't big but .073" IAB is were i'd start. I think you need to weaken the fuel circuit not necessarily restrict it. the the larger air bleed will reduce the fuel circuit sensitivity. i'd also get the centrifugal advance in as fast as possible and maybe forget the vacuum advance; if your using it.
So I installed the .033 IFR and put 72 IAB in it tonight. I have since realized that this motor will not idle below 850-950 RPM without running pig rich. I raised the idle using the secondary screw and ran it up to 950-1000 in which it cleared the idle up considerably. I fear with the big cam, and 8.5-9 in/mg. of vacuum, there is no way it'll clean up at the low idle. It seems to run alot better idling at 900 or 950 then at 800 all day long. The idle screws are a smidge under 1 turn out on all four corners. I think I have got it atleast do able for now with how it is at the moment. I am going to a car show Wednesday, so I will take it for a ride after all my idling and tuning and clean the plugs off good for a good blast. I will then judge where I am at after a little cruise.
