Ironbuilt
- 12:54 PM
- Jul 1, 2017
- North Carolina
Nice link, no sizes. They don't want you to know.
No prices either so I imagine they are stupid expensive. Did you carry taps that size on the truck?Nice link, no sizes. They don't want you to know.
Yes for particular applications. Otherwise just up to 3/4"No prices either so I imagine they are stupid expensive. Did you carry taps that size on the truck?
No, i only know it’s a straight thread , small Chrysler screw in ball joint style k772Any idea what size and thread pitch?
http://www.victorypp.com/inventory/37No, i only know it’s a straight thread , small Chrysler screw in ball joint style k772
Thanks so much , this I want to hear , exactly I get it one turn in and after they stuck and you must use minimum a hand wrench and of course the correct special socket . Thanks !!!The ball joints are kind of a tapered/friction/self taping unit. You get them started, maybe one turn by hand?, and then use the proper ball joint socket to tighten them down.
Thanks ! I see this site also , but also not easy to order . I write a e mail to them . And the LHC Left hand chassis I also In contact with them . Means I think I get my tap anywhere hopefully soon , and can reinstall my lower arms.
I've done the same especially with Shineeeese joints!What "Thrashingcows said",
and you have to make sure it goes in straight, and Try not to ever back up; the BJ sortof cuts it's own threads as it goes. It should take ever-increasing torque to get her all the way in.
If it gets loose towards the bottom, this is bad.
In the past when that happened to me, I would just drive it in and place three generous welds around the perimeter to keep it in there.
But when you do this, you have to keep the heat down because some BJs have heat-sensitive materials inside them.
One last question about this theme .Cool.....what some have said - the ball joint goes in by finger - then as it tightens up you use the special socket. Actually been that way since 1957 when Mopar started using them. Some early GM's used the screw in BJ as well. Glad you got some help with the shipping over to there !
