SS spring shocks?
67charger383
10:44 AM
Maryland
What shocks should I run with my 454/455 SS springs?
Car will have a reverse manual valve body with a transbrake.
3800lbs
4.11 gears
12-1 compression nitrous 383
8-3/4 because I won't buy a Dana until I blow it up.
MP SS shocks?
Hijackers with extensions? (really like that damn rabbit sticker)
Rancho's from a '70s Dodge truck?
What do you guys run?
:popcorn:
For a street car, I use late '60's Chrysler Imperial shocks. They have longer extension.
3800lbs
4.11 gears
MP SS shocks?
:popcorn:
Dodge truck shock from Napa
Much like said above, all have been used. I for one did the early Imperial shocks and the truck shocks.
Now a days most shock companies web sites have specs on the different lengths available.
Oh yeah,Air shocks is a "Up to you" type thing.Not much used anymore.
Depends what you want to do with the car. I used QA1 single adjustables on all 4 corners.
Measure the extended length needed for rears.
I have the same SS springs on my '67 Satellite. I used to use the Monroe-matic truck shocks on my car when I was running bias ply D.O.T. slicks but when I switched to drag radials the car would hook, then start spinning 30 feet out. I switched to the Competition Engineering 3 way adjustable shocks and that problem went away and my 60 foot times improved.
I run the MP longer ext shocks on my 63 with the 3400 lb SS springs. Ron
