I started my MP XHD leaf spring install today, and it was more challenging than I thought getting the springs off. I recently put new Bilstein shocks on and the rubber bushing must still be nice and sticky because that was a PIA just getting the shock bottom off. To hell with that, so I took the top off and finally got the bottom after using a pry bar and wiggling it. Just wouldn't budge. The U-bolts were next. I've got the rear frame rails resting on jack stands, and the Dana pumpkin sitting on a jack with the tires off the ground. Loosened the U-bolts loose and got 3 off, and as soon as I got the 4th bolt off, BAMM, the spring sprung open and crap went flying everywhere, and the Dana pumpkin just about slipped off the jack (but luckily I left the tires on and if she would have fell, it wouldn't have been far). After that I put a jack stand under the axle side I was working and put the jack under the spring to take some tension off as I got the rear shackle off. None of the Mopar magazine articles discussed this issue, and in the other leaf spring discussions here, it wasn't mentioned. Did I perhaps have the rear axle lifted too high so the leaf inevitably would rebound more?
Not sure if it was my procedure, but for others, read the Service Manual. It states the springs should be hanging down with axle slightly supported so that the springs don't fully snap and rebound once the U-bolts are taken off.
But here's a couple pictures of the tired leafs compared to the new MP ones, and one of the front hanger bolts was actually missing. Glad I got the new AR Engineering ones.
