Yeahrightgreer
While the motors out I think I’ll just add new rings and bearings. Take the car to the track, make a few passes and see where I can at. Based on that, may change the front tires from 245/60/R14s to M/T Sportmans radials and the rear to 275/60/R15s. Also some lighter wheels. The car has what looks like a 10” converter in it now so will then find a converter that matches the rpm range of the cam if it isn’t already.
Been staring at performance sheets of the trick flow heads and they do look like they give some great flow. Might just have to wait for a day where the Kit which includes all the gaskets, rocker arms shafts, cam and heads are on sale...
On the topic, is it worthwhile to switch to a roller cam configuration when I change the heads and cam? Or just stay with the flat tappet? I know trick flow makes a set of heads for both flat tappet and roller assembly.
What would do you think is suitable?
750 holley is 2 small probably now.
. But several companies offer the pressure fed bushed roller, so there are several options.
