showard
The dash was one of my hardest things to get set right (electrical). Looks good!
Thanks! Had to get the dash in place to get a grip on the layout of a number of things.The dash was one of my hardest things to get set right (electrical). Looks good!
Yes, and thanks for the heads up on the FPR/Filter unit.I love your build! It is going to be a great ride and you will enjoy the upgrades for sure. I did a similar build on my 68 Charger except used a 6.1 and 5 speed auto trans. One thing bothers me though and not to piss on your parade but I have some reservations about your fuel system and using that GM fuel regulator. I went that route with mine also and had surging issues and a lean condition. Long story short, it didn't provide the 58 psi the Hemi likes. I suspected the throttle body at first because at light throttle it felt like it was opening and closing as if it didn't really know what to do. After replacing that with no change, I finally scrapped the only GM part on my car and ordered up an adjustable regulator with a gauge. I can't guarantee you will have a problem with it but a lot of us have. Just wanted to give you a heads up if you have any of those issues.
I cant force them to help me out.
There's a few treads about this issue in the new hemi section, and other forums.So right now the project has come to an halt
I ordered a complete Hemi Crate kit from Mopar Performance (via Mancini Racing) to make the gen 3 hemi swap as simple as possible.
As it turns out there is a very important part missing in my package.
Its something Mopar calls a "body harness" witch links the PCM together with my old chassi.
It also controls my e-throttle, fuelpump relay and alot more.
This "body harness" has now been on backorder for over 6-months and I´m getting frustrated of waiting to say the least.
So reached out to a couple of "swap experts" to help me find the pieces I need to fabricate my own harness. Been several weeks since a contacted these "experts" but I cant even get them to reply on my emails.
So, to hell with themI cant force them to help me out.
I will do what I usually do, solve my own problems.
I have a complete "engine harness" that came with my engine and I will pick that apart and fabricate my own "body harness"from scratch.
Wish me luck
View attachment 851491 View attachment 851492 View attachment 851493
Thanks!Seems like there is always problems of some sort. I had hoped the players would have gotten all their ducks in a row by now but guess not. I bought a kit from Bouchillon Performance when I did mine back in 2014. They convinced me to buy their kit instead of trial and error and claimed to have done a bunch of resto mods already. For the most part, I got what I expected but when I had problems with PCM not playing nice and sending 16.4 volts to the system, they already had my money so they abandoned me with a bunch of drivel about it being my wiring or a bad alternator, bad grounds and everything but the fact that they didn't reprogram the computer correctly. I got a lot of help from Chris at Hotwireauto. I knew the Mopar Performance guys were planning on a plug and play kit. They looked at my car a few years ago and asked a lot of questions. Maybe they will get it worked out soon. Too bad about the 6 month back order on the harness. If I can help with anything, don't hesitate.
Thank you!There's a few treads about this issue in the new hemi section, and other forums.
http://www.protouringmopar.com/showthread.php?588-Alternatives-electronics-to-control-a-5-7/page3
http://www.protouringmopar.com/showthread.php?1530-New-Gen-Hemi-stand-alone-harness
https://www.forabodiesonly.com/mopar/threads/hemi-swap-wiring-harness.178031/
The best for me is this:
http://diyhemi.com/lxpinout.html
Good luck.
Thanks "Showard"Good luck!
Your doing a great job. All of your problems are way past my knowledge but I am looking forward to seeing how everything works out.
Thanks "khryslerkid"Whoa, had to go back and see what engine you were useing when I saw the starter location. Lol
For some dumb reason I didn't realize they were on that side.
Really nice work! Great looking!
All of the gen 3 hemis with an auto trans has the starter on the driver side, but with the manual Tremec I`m using the starter ends up on the passenger side.
That also means that there are no aftermarket headers when using the stock k-member and suspension.
But as long as a have the stock cam in place I feel no need for any type of upgrade on the exhaust manifolds.
Ok, thanks for setting the record straight on that issue.Gen 3 trucks with Automatics were the only ones with the starter on the driver side. All of the Gen 3 cars used the NAG1 transmission (Mercedes) which had the starter on the passenger side.
DitoGreat to see and hear your car running!
I would love to hear and see it in person if you didn't live so far away.![]()
