To you guys that know alot please read
oldhemiguy
12:21 PM
wi
I have six good kelloge crankshafts have a new block 4.5 bore want to do a stock crank and 4.5 bore have a 68 barracuda and 71 challanger done right but leaf springs will go in ether i'm 72 last motor I'll probly build we are talking Hemi would you use the cranks I have or buy new I know let the next guy to 528
If the crank mags and is not a fuel crank you could go for it. Thing by the time you separately get the rods and pistons you might be able to buy a nice balanced rotating kit. Then sell off what you most likely will not use. What heads and valve train do you have?
Looks like if you want a shelf piston for a 4.505 bore, they are all for 4.15 stroke, a 528.
The 477 pistons I found are the wrong bore/stroke.
What is the history of the cranks? (any possible cracking/damage) If CCW and known good I would use but also like rpm.
Maybe could offset grind? Any goals? (hp, max rpm?)
Probably best chance to use your 3.75 crank is a 7.1 rod and a piston for 4.125 stroker 4.5" bore. Next challenge would be getting a rod that 7.1" for the hemi piston pin size or .990 piston to go w the .990 rod. But I thinks doable.
Should be a fun build. For starters... try diamond pistons and Manley rods.
