CHARGERSTEVEN
Well did you try the spray method,didnt see a posting of a new hair cut lol
Spark timing would be way off.Have you checked to see if the timing chain is off a tooth, etc?
If you decide to take the foam out (mine lasted 20 years) do yourself a favor and take the fill collar off. You will need to clean the inside, and it makes it much easier.Ok, Did some testing today. Not really sure what to say about the results. You guys tell me. A bud came by and poured gas in the carb as it shuttered. No improvement. He said he could see fuel gushing in from all the squirters as I revved it and as it shuddered. One thing that may have made it act a little different was that I had the air cleaner off and it wouldn't go completely dead. It seemed to run better and stall a little higher with the cleaner off. We also did the timing light test, it stayed blinking during the revs and shuddering.. Someone told me a year ago while installing my fuel cell that the safety foam inside it needed to come out because it would start breaking down and get in the fuel system. I don't think thats the problem but I may take it out soon anyway, it just seems it will be hard to get it out thru the filler hole, fingers crossed.. Another thing that seems to be going on is that it is not cranking as easy as it was a month ago. It acts like it is not getting fire while I have the key turned to crank and then it fires up right as I let off the key. Maybe the 52 year old ignition switch is ready to retire, it was pretty loose and worn feeling anyway. I have a new one ready to go in, just gotta do it. I hate working under the dash.. And I am going to take the vacuum advance hose off of the distributor also as suggested and see what that does, just ran out of time today.
I'm thinking the cam drives the distributor, so if the cam is late the ignition timing will be lateIf the cam timing is off the ignition timing would show as correct but the valves would be off.
Unless of course it has been adjusted after the chain jumped.
But if you then time the ignition to the timing marks.....I'm thinking the cam drives the distributor, so if the cam is late the ignition timing will be late
