Vintage Air in my 62 Fury wagon ? info wanted
rustytoolss
12:19 PM
New Franklin, Ohio
Going to install aftermarket AC/Heat in my 62 Fury wagon (318 poly). I have made the compressor brackets. Have been planning to use Vintage Air GEN II Super system. Has anyone used this unit in a 62-65 mopar before ? how well did the unit fit ? Any photos ?...Do not want to install an under dash system.
It should fit and work fine. These are universal kits so a lot is on the installer. For the most part its just a universal box. It needs 2 heater holes, 2 a/c holes and a drain hole. Mounting is just a few studs and a hanging bracket or two. All the rest vents, controls is position-able to your preference. I bought the Chinese knock off hose fitting compressor to make my own hoses as I ordered mine with a universal hose and condenser kit. This allows you to route hoses as well as the dryer to your liking. I had to get a couple extra fittings but that was cheap.
I am in the process of installing Vintage air in my 63.BUT I am using their Hot Rod under dash heat and air.
If you look at the GEN II specs/dimensions you can take the sizes to see how well it will fit.A cardboard template box may be helpful.
Looking at mine I feel you will have plenty of room under there.
VA offers empty evaporator units just for mock up. I put a VA set up in my 65 Belvedere. I was going to use the 4 outlet model but, due to my enlarged tunnel I had to switch to the small 3 outlet model. With a stock tunnel the 4 outlet will fit. I built a plate to block off the fresh air opening for the stock heater and used bulk head fittings in the plate for installation ease. I also purchased the " you build it" hose setup. Works nice. Still under construction.
Mike
Mike,Looking at that photo,you are installing the heater control valve under the dash and not in the engine compartment. Correct ?
I ask because I'm not sure where to put mine.I was planing the engine compartment till I saw the photo.
That looks like it is up in the passenger front fender well to me. That is how Vintage Air does it in their kits available for later B-bodies. All the AC and heater lines run out of engine compartment through the inspection hole on the right. This did not appeal to me, so I devised another way to do it. That is the front shock mount hole just ahead of the water valve.
Here is how I did my water shut-off valve. I keeps the hot water heat out of the cabin. I did not have room to plumb it inside, anyway.
Mike
View attachment 1353661View attachment 1353662View attachment 1353663View attachment 1353664
493 Mike, how well does your 3 outlet unit work in your wagon ? I had someone tell that the GEN II units did not cool very well in large vehicles. I am planning to install a GEN II Super AC/Heat/defrost in my 62 Fury wagon. Get back with me please before I spend money on the wrong system. Thanks Shawn N.E. Ohio
The VA unit I installed is in my 65 Belvedere 2 door and that has butyl/foil insulation with a full interior. I have not yet even fired the engine so, I have no performance info. Call VA for their recommendation.
Mike
I called Vintage Air, they said that the GEN II Super would not perform very well in a car as large as a wagon. And thought I would be far happier with thier GEN IV Magnum series system. So does anyone have any photos of installing a GEN IV system in a 62-65 mopar ???
I installed a gen 4, but I am really bad at taking pictures. I did quite a bit of it myself, my brother in law works for V.A. Made the hoses for me and helped me order piece by piece. I think I have an evaporator that is for a Tri 5 Chevy and some pre bent metal hoses for other kits. Big advantage of having my brother in law. I got a linear actuator so I am using my factory temp lever, I made an adapter and use my factory fan knob, and I put the selector knob in the ash tray.
Thanks for your reply. How well did the unit fit under the dash ? How well does the unit preform AC/ heat ? Where did your AC/heater hoses enter/exit the cab ??
routed the hoses through the fresh air inlet. I made a plate and sealed with grommets. Heat is really good, A/C is cold. I have two under dash vents and the factory pop up vents on top of the dash. The heater box fit well, I think it is smaller then the factory.
I have driven on 100 degree 90% humidity days and it is very comfortable on medium fan.
Thanks for the quick reply. Last night I made a fake cardboard box to mock the GEN IV sizes 10.5x10.5x26, and tried to stuff it up under my dash (did not go very well.). I have some more question before I would buy a GEN IV. 1 did you have the complete dash assy removed to install the unit ? 2 did you loose the uses of the glove box ? 3 How much foot room was lost for the passenger/ if any ? 4 was the 55 chevy evaporator box smaller than the regular GEN IV unit ? Sure wish you had some pictures you could share, or I could get intouch with your brother-in-law. These are big issues that I need to get answers too before I spend the money. Thanks Please get back with me.
I did not loose the glove box. I am sorry the condenser is for a 55 chevy. I took out my glove box and the radio while I was making the brackets. I don't feel that I lost any leg room. I can try to get so pictures tomorrow
Those pictures sure would help me decide on the GEN IV system. A guy can't have too much information on a project like this.. the more the better. Thanks SOOO MUCH .
