Water / Meth injection
HEMI-ITIS
STREETER on LI
2:40 AM
Long Island,New York
I would like to know if any w/m users were able to satisfy a need for 112 octane with pump gas & w/m injection.
I find my boosted carbs really like to spin faster,the cars are so much responsive when the blower is spinning faster and I prefer not to have to mix race fuel.Higher boost levels I would be using straight c12 on to 14 lbs of boost.
I run water injection on my 81 turbo trans am. (got tired of buying methanol, TTA sucks the gallon tank down quick). Used to get detonation at 7-9psi and sometimes lower when flooring it on the highway. Now I push 15 pounds of boost no problem, other than the 15 being way more than the factory head gaskets could handle. Going higher after replacing them.
No idea what octane rating the car is at with the WMI spraying. I always run it on 93 octane
What is your static CR?
Next "Q" is 8 lbs of boost from a roots the same effective CR as turbo or centrifical....
I use diluted windshield washer fluid, 50/50, guessing about 15% methonal. I run a blow through carb on my turbo system so the higher the meth number the more afr's are affected, so I tune for what I mix. A lot of water meth manufactures recommend running straight water if using a carb. Its the water that provides anti detonation, the meth content drops afr's. Ricers running 30lbs of boost will up the meth content if there spark plugs misfire. Easy to buy windshield washer fluid when buying gas.I have used windshield washer fluid for water injection, on about 4 different cars in the last 15 years. Not sure on the octane rating, but I helped a friend put a supercharger on a bmw 320i. 11 to one CR, had detonation at 1/2 psi of boost on 94 octane, after water injection we got to 11 psi and had to back it off cause the clutch was slipping. he spanked on the car for a couple years until his girlfriend crashed it. I think I"m running about 750cc/min worth of nozzles on my 440, with about 6lbs of boost, its more nozzle than I need to run.
I know snow performance advertises 116 octane plus with there system, I don't have the experience using fuel with that high of an octane, but my guess is they are understating the capabilities of water meth.
In the past, I have bought straight methanol in the paint section at the local hardware store, to mix 50/50 blends with water, One car I had, I even had the water meth intake hooked into my windshield washer reservoir.
It's so hard to believe they can satisfy the demand for 116.That is the reason for my post!I can go to 13 lbs on 112 and then require 116 above 14 lbs.So I doubt I will ever need 116.My heap has been 9.3 @ a click under 147 with 6 lbs through the exhaust being CHOKED!
When I increased the boost to 10 lbs it separated one of the slip tubes in my left header.So then we put dumpers on.My fat bitch weighs 3700 with me in it.
Carlisle 1018 009.jpg Carlisle 1018 010.jpg Carlisle 1018 011.jpg Carlisle 1018 013.jpg
I have mixed at 7 lbs in the street,few test recordings i the street checking AFR and boost.
