What could be wrong?
pedal2themetal
4:15 PM
Idaho
HI,
Ok I've got the over heating under control .. but now I have a loss of power and when I get on it I have that Blap Blap sound in my exhaust? did the times of overheating hurt my motor????
it seamed to be fine right after I fixed the over heating but now its doing this?
and the idiot light coming on at idle? i think that is the oil went bad going to change that and filter
First of all, what did you change to fix the over heating issue?
Did you touch the timing?
Did you loose oil pressure at any stage?
If you're suspecting that overheating damaged the motor, do a compression test.
HI,
for the over heating I replaced the radiator with one from ECP (Enginnerd Cooling Products). Now it barely gets over the 1/4 mark on the gauge with a 185* stat. going to go up to a 195* stat.
I replaced the oil and filter and the idiot light went away. so It was the oil loosing its viscosity. I think the shop that R&R my intake and heads used a crappy oil (cheap)
As for the Blaping in the exhaust , I'm going to replace the spark plugs and wires I'm thinking they are due anyway.. I'll up date when I get that done on that .. I was having some elect. choke problems got that fixed (replaced the connecting wire). So I may have fouled some plugs.. and the wires are funky looking and too long so may be cross firing.. need seperaters.
HI,
OK. Plugs looked good but I replaced them anyway... didn't change anything. still popping.. Vacuum gauge was good only bouncing very little 1 Lb 14.5 to 13.5 .. so I took a stethoscope to it and found a bad leak in the EGR system I had plugged up. I made some plugs to go into the EGR cross over in the back of the heads. and the one on the passenger side is leaking bad. So I'm going to pull it tomorrow and see if it needs re welded or just a better gasket on it..
HI,
OK... the plug in the back of the exhaust crossover did quite the under hood noise a little. but not the problem.. At this point this weekend I'm going to pull the VC's and check it out I'd almost bet I got a broken spring..but we'll see. Springs are a new set of 901's.. as suggested by my Machinist ..
I just noticed that my stock springs were double with a dampener spring.. If I got a broken spring I'm going to see if the old stock one's well work?
? What is the difference between the 901 and the stock ones anyone know??
And the first thing you did was a compression test, right ? What were the results ?
HI,
Nope.. motor runs smooth. just pops out the intake when giving a little throttle like 1/4 throttle. Vacuum gauge is quite steady only vibrates 1# 13.5 to 14.5 at idle 750 rpms.
