- 6:23 PM
- Apr 13, 2012
- Granite Bay CA
I installed the glass in my Charger today. The Wife helped me set the glass.
First off, I ran a thin bead of the 3M8509 non hardening bedding compound along the flange all the way around. The gasket was pressed into place, then Wifey and I placed the windshield into the opening. I started from the top like the FSM shows.
The LH corner was fitted first, followed by the RH side. I had her press the gasket outward as I pried the glass into the gasket from the outside. I did manage to get a 3 inch tear in the outer flange at the bottom middle. I was tempted to just call it a failure and pull the glass back out, then order a new gasket. With the thought that I had little to lose, I pressed on. I squirted the urethane 3M 8609 into the glass channel after finishing the lock strip. I'll do a leak test tomorrow. If all is well, the trim goes back on.
