bluepainter
I pulled out my steering column to fix my reverse switch,but to do that, I had to disconnect the two shift cables. When I put everything back and started the car, it would go into drive and neutral ok , but when I put it into reverse it chatters and wont quite go. Could I have the column not quite where it was ? Oh yeah, its a 65 dodge coronet 4-door 318 poly.
