Propwash
- 4:55 AM
- Oct 29, 2009
- Island of Misfit Toys
Wow! That all brings back some recent precious memories. All I can say is.......Hell Ya, tear it up Dave!!! Looks like you're set on supplies till 2050..lol
Your rockers....Patch them if you can. Inner rockers are not too bad to patch, they're flat. Cut out some 18-20 Gauge and graft in..The outer rockers are pinch/goobered welded between the interior framing and inner rocker in that back area. Definitely a pain in the *** to get a part. I ended up buying both new outer rocker for my RR from AMD. Not Cheap, but I ended up replacing a great majority of both rockers. I'm not sure if anyone sells patch sections for outer rockers. Did you or are you planning on changing out both rockers?
You could give it a shot to make your own patches back there, if your not looking to buy whole new outer rockers and can't buy repair sections. A trick I've used in the past to fabricate sections of panels, and didn't have no serious equipment to properly bend/break metal...If you got a decent sized vise, tac in some 3/4" square tubing across the lips of the vise and a couple inches longer than the patch to be fabricated. Secure the fresh metal in the vise and start working down towards the angle you're looking for. I don't hit the fresh tin directly with a hammer. I use a piece of 2" square tubing. That way the impact is spread out across the metal and helps bend down a uniformed bend. Work the metal down back and forth like a typewriter. Once you get the metal close to the angle you desire, switch to a piece of 1" or 3/4" tubing your hitting your hammer on. After that, fine tune with a body hammer and dolly. That 3/4" tubing that was tac'd in the vise will help create a soft yet fine curved edge that's uniformed and doesn't look wobbley all the way down the bend..
Just my 2 cents....
Definitely enjoying the show! :sixpack:
Just my 2 cents....
