Installing a Chrome Box?
code_red
8:54 AM
Indiana
I am replacing the stock ecu unit with a chrome box. Is it a straight swap or is there more that needs to be done?
Assuming it has the plug that matches yours it is a swap, Nothing else to do. Make sure the ground is good. I ran a separate ground to make sure I had a good one.
I have to back this up especially the ground part and DONT run cheap plug wires......Artie
Does the ballast resistor matter? I have one like this.
(sorry for all the questions. This is all new to me.)
Ecu
The ECU should be matched with the proper resister and coil. If it's a Mopar Performance, check their part numbers for reference. The attached link may help you determine what you have and/or what you need.
http://www.mymopar.com/index.php?pid=18
I think I need to get a different ballast resistor. I don't know about the coil. It read 12v and made in Mexico on it.
