fatecaptured
Well reading some of the engine builds and suggestions, I've decided to post my build and see what people think. This was my first attempt at a street and strip 12 second b body. If the parts sound like they are out of left field, it because I was a noob and didn't have access to a community of people such as this. Take it easy on me and remember I only had a couple of books and no experience. I tried to go by these two books mostly ( Mopar Performance and Big Block Mopar Performance). And I got advice from the mancini tech line.
PAW 440kit: 1975 440 .060 over, 1/2 oil pickup, steel crank, speed pro 2355f60, 452 heads
Mancini Racing: 292/292 .509 purple cam, Comp Cams pro mag rockers, ARP main studs, 3/8" High tech pushrods, sfi flex plate, performer RPM, 800 cfm thunder avs,MSD pro billet dist, blaster coil,msd 6al box, msd wires, sfi bhj dampner, 1 7/8 hooker super comps, pypes 2 1/2 x pipe with turbo race mufflers.
Transmission: 727 with tci kit, shift kit, kevlar rear band, and Turbo Action torque converter 3800 stall..
I also added a mini starter, jeggs aluminum radiator with an electric puller fan and thermo switch.
I had a mechanic do the assembling , I installed the engine and trans, and did all the hook ups. Its been sitting since '08. I'm nervous about the out come. Im trying to get the breaks done before i prime it and start it, just so i can take if for a spin and be able to stop this sucker. After reading about some of the peoples stall speeds, i'm kinda wondering why they (mancini)recommended such a high stall. And for the record i haven't touched the rear end. Kinda want to get it broke in then go messing with that after wards. Oh and it has a new gas tank and 3/8 line and 1/4 return line.
