Coronet 14
Due to medical issues I haven't been on here for a while. But things that have been checked for carb backfire. Compression good, Vacuum leaks fixed found old roller bearing shoved in vacuum hose weird. played with timing made backfire worse. Set back to where I had it. Same with vacuum advance. Adjusted carb jets. set underhood insulation on fire Bad no marshmallows. Carb still intermittent backfire. Pulling carb off next week. Gonna have checked and bench flowed. I would put a larger motor in this car but I want to know what is going on I won't surrender.
