Someotherguy
were almost there it looks like
Can I start it with the battery charger on it?
depends on which kind of battery charger you have...some are designed to jump start a car along with just charging the battery, some are not...there will be a jump start selector switch on the charger somewhere if it's capable of jump start also
the starter sounds like it may be dragging due to low battery charge.. or you may be waay out of time....
How long do I let it charge for?
yeah, it wont hurt to flip it around....thats prolly the issue there since you didn't mark it...
let it fully charge....say about an hour...
not on a small block mopar, the distributor is keyed, you are either 180 out, or right on....since he only replaced the heads(i assume?) then the cam timing shouldn't have been messed with...
DOH!! My bad, assumed it was a big block car.
He needs to slow down while doing his trouble shooting. Personally, I would have checked the battery volts first to see what that was. Once I knew whether the battery volts were good or not, then I would have moved to turning the dizzy 180 degrees. Its been beat into me to make one change at a time.
Yeah sorry, I've been sitting in my garage all day hitting refresh until someone comments, then I do whatever they say. I'm a little impatient.
Yep I generally know where the vacuum canister is supposed to go, I remember.
