Boise68
I picked up this 400 last weekend, with the option of another if the block is not salvageable. It was stored inside for the last 20 years and still had oil on the cam and lifters beneath all the dust.
First surprise came when I tried to loosen the crank bolt to remove the damper. The fella I bought the short block from thought it was froze. Not. :hello2::hello2:
The crank turned easily, the bore checked out to stock bore too. There's a ridge at the top of bore but without a bore dial indicator I am not sure of the actual wear. Any recommends on a bore dial guage?
The second surprise was the double timing chain set. Did all 400's come with double timing chains? I've read that some police and hp 400's came with this option? I am going to remove the rotating assembly this evening and get the first look inside. Any watch-outs or suggestions? Thanks ahead all, :nike:
