robw13
I've looked high n low on my charger and cannot find a fuel filter anywhere?. Where's it suppose to be on a 5.9 360? 2 lines from the pump, 1 to the front of the car and the other to the tank.
I put a line on the steel line that feeds the fuel pump ant to a siphoning rig to a can below the car tank... cranking and wiping out the motor with starting fluid is dangerous and if you're timeing isn't right retarted.1st, do as the others have said, put a filter in line. Pretty sure it was just before the fuel pump (along the frame rail) on your year car. Then follow the steps below to see if she runs.
Step 1: Spray some carb cleaner or starting fluid down the carb, then crank it. If it won't even 'try' to start, you have other things to check on with the motor (functioning carb, distributor, ignition relay, ballast resistor, etc.). If it tries to run, move to step 2.
Step 2: Run a fuel line from a gas can to the fuel pump. Again, spray the carb and try and start the car. If you can get it to run, but only while spraying, the fuel pump likely has a bad diaphragm...the pump would need replaced. If the car does run off the gas can, the fuel pump is good.
Step 3: If it runs from the gas can, hook the fuel line from the tank back up and try it again. 3 gallons in the tank is plenty to get her started...provided nothing is plugged as mentioned in earlier posts. If it runs off the cars tank, you are in business.
My car had sat for years. We cleaned the old points (yours should be electronic ignition...no points), sprayed the carb and she fired right up. Ran a hose from a gas can to the fuel pump and she would run as long as we sprayed the carb. Swapped out the fuel pump and she would run...off a gas can. Hooked the line back to the tank...nothing. Dropped the tank & removed the pickup/ sending unit. It was full of gunk and the inside of the tank looked like a cavern (stalagmites everywhere) Tried to put air through the hard line and hardly anything came out the other end. Replaced tank, pickup and hard line and all is well ever since. I personally don't believe you can get the tank and hard line good and clean for less than what re-pop parts cost. I once replaced a Duster 340 tank with a used one (years before re-pops). I would periodically have problems with that car after that.
Depending on how long the car has been sitting, you should consider replacing the tank, the fuel pick-up/ sending unit, and the hard line from the tank to the fuel pump. Or, you can chance it, but you may continue to experience issues over time.
Good luck!
use 5/16.If I were to replace the fuel line from tank to pump, anyone know the size of it?
