OhioMopar
Here are pics under my Bee. Should be the same.
			I was an idiot and sent my old floor pan to the salvage yard. Does anyone know specifically where the parking brake cable bracket gets mounted? A picture and diagram would be great. I know it's drivers side toward the rear of the floor pan...but I have no idea where to weld it in.
Rule#1
Never discard anything coming off the car until you have it all back together...
		Also, I have another question. This car has 11 inch drum brakes in the rear and 10 inch in the front....was that common?
I should add that I'm a relative noob at this, so I might be wrong.
Looking good.
Cap... for all 69 RR's I think it should have had 11's on the front? If I recall, 11's and a sway bar were 2 of the defining features of the RR that were stock compared to a Belvedere or Satty, where they were options...
I'd agree...My Bird and Coronet are 11" all around cars. 11's in the Front & Rear. When you think about brake proportioning, your fronts brake about 70% of your total braking. I can't see Mopar putting on a smaller brake in the front, because that would definitely be working against the concept of keeping a majority of braking up front. Keep up the good work!
So, if I wanted to keep the front on a drum system, I would just need to upgrade the backing plate and drum, correct? Would I still be able to use the hub and spindle?
I was able to get a couple of hours in the garage today and stripped the doors... found a lot of bondo and rust, not sure if I'll be able to save them.
On a side note, I broke a couple of studs today. Does anyone know if there is an aftermarket provider for this support bracket that came out of the door?
And before they were blasted....yuck!
		That's what this hobby is about. Helping..Thanks Darren...Appreciate it!
If you decide to go with 11" drums, let me know. I have the ones off the Bee I'll never use again.So, if I wanted to keep the front on a drum system, I would just need to upgrade the backing plate and drum, correct? Would I still be able to use the hub and spindle?
