After just getting my Charger restoration about buttoned up, I am really liking the power of the 440 in it. 488 hp & 541 ft lbs. I have a #'s matching 69 Road Runner that I would like to have similar power, or fairly close. When doing a little research, it seems that a 400 block with a 440 crank is a good reliable combo. I would pull the original 383 and set it in the corner. 1971-74 400 blocks are the best? I have a 440 steel crank that could be used. Looking for opinions on a build from you who have done this. I want to use the hp factory exhaust manifolds. I will put on new TTi 2.5" mandrel bent exhaust with Dynomax mufflers. I am happy with the Stealth heads on my 440 so am not opposed to using a pair for this build, unless there is a better option (I have a pair of extra 906's). I will not use another RPM intake because of height, so am thinking maybe a Holley Street Dominator, although this is a single plane. I like the Holley 770 Street Avenger on my 440 so would be happy with another on this motor. Mopar Performance electronic ignition.
So the car is a 69 RR, 4-speed, 3.91 rear (I wouldn't mind going to a 3.73 or 3.55 someday), 28" rear tires. I want a reliable motor capable of running on 91 octane pump gas. The car will never be raced, but looking for some spirited stoplight to stoplight action with plenty of torque. I have a solid cam in my 440 and have no problems using another in this motor. What do you guys think?
