Ready to start 5 speed swap on 69 Charger
Ductman
12:20 AM
South
:glasses10: So the car is on the lift ready to go. I wanted to get a few pics before I take out the A-833. The 5sp set up will be here in a few days.
Which 5 speed set up did you go with? The more info the better! lots of people around here thinking about a swap like this
I purchased a RS600 from another member of the forum got6pak a few days ago. It's on another post with pics of all parts but I don't know how to move the pic to this thread.
Ain't That Perrdy!
Here is a pic of Shifter Handle I got from passion performance. I was going to try a A-855 but was told 10 months before I could get one. I found this other set up and the price was a lot better and he had it in hand no wait.
Is this a Richmond? Sorry not familiar with the Model #.
Google tells me it's a Keisler
From Pro-Touring Forum ;
Keisler RS600
Anyone planning on running the new RS600 by Keisler? Sounds like a pretty cool alternative for something in between the TKO 600 & the T56 Magnum being based on the T45RS platform and requiring zero floor mods. Below is a portion of the e-mail I got today from Jeff over at Keisler in response to a few questions I had......
"This is the new line of transmissions we have been developing since `07. We're approaching release soon and hope to have these ready to release by January. The RS600 is an upgraded and redesigned version of the T45RS that we sell now. It will not require any cutting, will shift at higher rpms and have the same smooth shift quality just like the T56. This trans is essentially a 5 speed version of the T56."
"This will use the same bell as a Muncie 4 speed and gearing will be: 2.80 1.99 1.33 1.00 .67 o/d. "
More literature from Shafi @ Keisler
Keisler RS600 5-Speed
Hi Guys and Gals,
We will be launching the new Keisler RS PerfectFit 5-Speed officially next month. We debuted it at the Chicago Muscle Car and Corvette Nationals last weekend. Here is some info about it, compared with our previous offerings. As this product will prove itself in the months and years to come, it is a major advancement in the market, and is Keisler's new flagship product.
DESCRIPTION ... KEISLER Rallye Sport "RS" 5-speed
The evolution of the Keisler T45RS line started back in 2007, the Keisler RS 5-Speed product line takes our overdrive transmission systems to a higher level of quality, value and performance.
1) A Perfect Fit
Thanks to an all new feature rich extension housing case and a heavily revised shift system, we are able to package the RS as a PerfectFit for a no cutting, no compromise fit in most popular muscle cars and classic sports cars. PerfectFit with the RS is standard - not an upcharge (like our tremec tko perfectfit kits). More than 15 shifter handle mounting positions exist for all popular domestic cars, sport trucks and kit cars.
> GM A-body NO CUTTING - For the first time ever, owners of Chevelle, GTO, Skylark, 442 will be able to install a 5-Speed with NO CUTTING to the tunnel ... a major improvement over our tko perfectfit kits. The RS provides uncompromised driveline angle and assures your engine won't be tilted back with exhaust headers pointing down to the ground, and you won't have driveshaft vibration - typical problems found when a tko is installed.
> GM F-body NO CUTTING - owners of Camaro and Firebirds will no longer have to notch the shifter hole and use a compromised boot sealing arrangement (req'd by tko).
> Corvette NO CUTTING - the main advantage of RS for Corvette owners is that there is no compromise of the driveline angle, and there is MUCH more clearance between the transmission and floor tunnel.
> GM B-body, NO CUTTING - For the first time ever, owners of Bel Air, Impala, Biscayne and other apps will be able to install a 5-Speed without the major tunnel surgery typical of the tko.
> GM X-body and other apps like Cobra kit car having a shallow tunnel will greatly benefit by the RS PerfectFit design, allowing installation with little (gen 1) to no mod (gen 2) to the floor tunnel, while keeping perfect shifter position. Again, these
2) Unsurpassed Shift Quality, High RPM Shifts, NO 2-3 Misssed Shifts
Thanks to the Borg Warner designed carbon fiber lined Blocker Rings in all gears, and Double Friction Cone system in 1st and 2nd gears, the RS features the best shift quality of any aftermarket manual transmission (including tremec tko, 3550, 3650, t5, t56, Richmond). At Keisler, we redesigned the shift systems of reverse, added bearing support under the shift forks and other portions of the single rail system. While the BW T45 was designed several years after BW T56, and shares it's synchro system design, the shift quality is even better than T56 because the shifter rail/fork/interlock system has less mass and fewer joints. The result is a very nimble shifter feel. Additionally, the advanced carbon lined synchro system has a much higher coefficient of friction than paper lined blockers, or just plain brass blockers (like TKO). The result is far less shift effort at the handle. The shift quality right out of the box is clean and smooth with no break-in, and a world of difference better than the best highly modified, proshifted TKO; withouth the big price adder.
The Keisler RS cleanly shifts at 7000rpm - more than 1000rpm higher than TKO's 6000rpm cutoff.
The RS has a guide plate shifter system unique to any manual 5-speed on the market. This guide plate mechanism cleanly guides the shifter in/out of gates 1-5 & R. A 2-3 miss shift so common to TKO - as many of you already know - is nearly impossible with the RS. I haven't been able to miss a 2-3 shift with the RS.
4) Close Ratio & Standard Ratio Gearsets
Standard Ratio Gearset - 3.37, 1.99, 1.34, 1.0, .67 (1.38 step change in 1st, 33% RPM drop in overdrive)
RS400 (400 torque): 1-1/16 x 10 spline input shaft, SAE 8620 nickel-moly steel alloy
RS500 (500 torque): 1-1/8 x 26 spline input shaft, SAE 9310 chrome-nickel-moly high strength steel alloy, CNC ground gears
Close Ratio Gearset (new)- 2.80, 1.99, 1.34, 1.0, .67 (.81 step change in 1st, 33% drop in overdrive)
RS600 (600 torque): 1-1/8 x 26 spline input shaft, SAE 9310 chrome-nickel-moly high strength steel alloy, CNC ground gears
3) Lower Cost and Better Value than previous offerings
Keisler Engineering created the business of retrofitting Tremecs and have sold more than 13,000 of those units since 1999.
The Keisler RS 5-Speed now sets the new benchmark of the flagship overdrive transmission system. And, we've managed to do it for hundreds of dollars less than the tko. And we're going here in the USA - gears, cases, shifter components
5sp RS600
No the handle is only 4 speed on lens.Im hoping the other one with the kit does.
Legend Lgt 700 is Still available and I believe is the newest version of this trans.��
Sounds pretty cool, I'll be watching.
Can anyone tell me these numbers ID match
a 69 charger 383 4sp
Interesting thread I'll be watching too
:clock: Waiting on shipping!Supposed to be here tomorrow.:worry:
Does anyone know for a B Body Mopar is this supposed to be a direct swap with limited alterations and tunnel mods?
This Nos "Perfect Fit Kit" from Kiesler is supposed to be no cutting. We will find out soon I hope.
I called SST and they only do tremec TKO trans now with the "perfect fit kit" and They said on a Charger yes with a TKO You must cut the tunnel. SST got part of Kiesler after they went out.
I called liberty Gears.They acquired some part of or rights to a design from Kiesler involving the TKO as well.Libery make some awesome stuff.
From what I understand but not sure -Legend gears is who made this RS 600 for Kiesler :thinker:.
That handle will not work; it's bent/formed for the 4 speed side linkage and all RS/SS/Legend/TKO units come up through the tunnel on center. That handle will be on the passenger side of the tunnel when installed.
Silver Sport Transmissions is the company that took over all of Keisler's stuff. From what I've read they can handle any parts or service requests for Keisler products.
www.shiftsst.com
You are correct Sir.
Cutting is indeed required on all RS/SS/Legend/TKO installs because the shifter comes up through the tunnel on center instead of through the shifter hump like the 4 speed. If you have a console, specific handles are required with an adapter to keep the handle in the console. You'll also need a small sheet metal patch to seal off the old shifter hump.
