62 Dart Convertible
Hi Guys. I've seen a few threads where some have thrown this idea around, but I have not found definitive results or conclusions, so I'm asking for educated thoughts or experiences.
I usually only drive my car every few weeks, and when I go to fire it up, the carb bowls are absolutely bone dry. The mechanical pump takes an age to fill the carbs and the poor starter gets a hammering before the engine finally fires. (Having dual quads I imagine makes things worse compared to a single carb as I have 2 carb bowls to fill up ...)
So, I have bought one of these Holley Elec pumps to install by the fuel tank in order to prime/fill the carbs before cranking -
My plan is to only energize this pump prior to cranking for long enough to prime the whole fuel system so the engine starts instantly.
As usual, I have been perhaps over-thinking it all and have concluded there are 2 different plumbing options to fit it. A simple way and a more complicated way -
I'm sure the simple way would work, but is it possible that at full throttle, the de-energised elec pump could restrict flow on the suction side of the stock mech pump enough to starve the carbs of fuel? (If so, that's why I thought the more complicated way with the elec pump in a TEE branch would minimise suction side restriction. The non-return valve is a necessary addition so the elec pump flow doesn't just recirculate when it's energised.)
Proposed non-return valve -
Also, to energise the elec pump for only a pre-set time when I turn the key to 'ON' and before cranking, I would use a small electronic timer like this hidden under the dash -
Thoughts?
Thoughts?
