Carb install
rrTor-Red
9:08 AM
USA
Installing carb soon. Would you guys use studs or bolts through the carb into intake or use studs in the intake then carb? Does it matter? Aluminum intake if that matters
I like using studs. It aligns and holds the gasket and the carb when installing. Stuff doesn't slide around.
If you plan on possible changing carbs and testing etc, studs are a great way to go. That way you're not always threading a bolt into the manifold.
ARP is the premier company in automotive fasteners. However, the carb studs are not under a lot of pressure unless you are trying to pull your engine via the intake manifold which I personally would never do. Companies make carb studs that are about 1/3 the price or less and some like Mr. Gasket or Spectre have a hex top that makes installing the stud much easier. I've also seen studs with an allen head for installing.
I like the those and or if I can find a hex but would prefer them in stainless. Haven't searched for them as of yet.
