Hey guys. I loaded my car up and took it to my Dads auto repair shop that's a few hours north of where I live. We put it up on the lift and started checking it out. Brakes all look good and I greased all the suspension parts. I noticed a label on the drive shaft and it says it was balanced. I know a new tranny was put in not long ago and it looks like they had a shop do a new drive shaft. I also saw this strange transmission pan. It's got a built in cooler and a buddy says its aftermarket.
I put some decent tires on the car and I'll be leaving it with my dad for a while. He is going to fix the oil leak and then run the car a while to shake out any bugs. Since he owns a shop and tow trucks it's easy for him compared to me in the city.
I was disappointed in one thing I found. I knew the old owner told (after I owned the car) that he had swapped the center section out of the 8 3/4 at some point. I knew the sure grip was gone and it was an open unit but I hoped to build it with a limited slip later. Turns out he put in a 741 case. All my reading says that's the worst one to have. I also did the turn the wheels and count the drive shaft rotation method and found the gears I have now are around 2.9. I was hoping for 3.55.
My dad used to be a body man back in the past so he just started attacking a lot of my dents. In just a few hours a lot of them came out so that was nice.
What do you guys think of the 741/gear thing and about that tranny pan.
