Update, this evening:
I got the new gasket and locking Ring I ordered from NAPA (Spectra #LO06 for those playing at home). I only wanted a gasket, but for $4, I ain't complaining.
What I have NOT received yet is the new MOPAR locking ring from MoparMitch.
Well, time's up. I wanted to do this on the weekend and I'm not one for patience (you die a few times like I have and you get that way). It should have been here by now.
No worries, I still have my original equipment one. I cleaned it up with a wire wheel on my Dremel and off we go...
Look at the difference in thickness between the new Spectra on the left and the original on the right. The original feels twice as heavy and has more "meat" in the ramp areas that slide up under the locking tangs on the tank.
Sorry, Spectra, you lose.
New gasket looks good and has a little overlap all around. I centered up the sending unit and had a look. Looks real good. Ok, locking ring time (I decided on no sealant).
Original locking ring fit really snugly and it took some time to drive all 3 locking nubs on it into place in the tangs of the tank. The fit felt really tight and I was unable to move the sending unit at all once installed.
I used the same brass punch as before and there were literally dozens of taptaptaps involved to get the locking ring fully seated, so I'm very satisfied with the fit.
BTW, notice how the zinc is flaking off the tank already?
Yeah, like I said, y'all don't buy any tank that's described as "natural steel with zinc". Just don't.
I gave it a quick shot of clear to try and seal the surface.
I also cleaned up the nearly new straps and off I went....
Tank is now re-installed in the car.
I reckon we'll see tomorrow when I put some gas in it. Wish me luck!
