Hemirunner
Same here. I agree 100%All in all, the tubing is relatively cheap - it's the foam board that is a little salty.
I have hydronic heat in my shop and it was the best decision I've ever made.
Thanks and yes I spelled purlins wrongThe term you are looking for is purlins, not perlings. Just busting you balls a little. House wrap over the purlins would help with draft. Skip the kraft faced insulation and run a 6mil plastic vapor barrier on the inside of the studs. You never want to install kraft faced insulation on the face of the studs, only on the sides. If you overlap it on the face of the studs, it makes it hard if not impossible get the sheetrock tight to the stud. Eventually this leads to the screws and nails "popping" after it is mudded. You are right with your thinking on getting a good tight envelope to seal the building. If you have any questions feel free to PM me, I've been doing this stuff for a long time. Jason
I don't get it, he's got a backhoe and a truck so hows he making money if his equipment is here doing nothing?Now you know why I do EVERYTHING myself. It usually turns out better than most of the work I've paid for.I hate hiring people........ I'm 2 weeks past my excavators original estimated time for finishing this, he shows up as I'm leaving (10:30) and I come home at 5:00 to a hole I could've dug by hand!!I don't get it, he's got a backhoe and a truck so hows he making money if his equipment is here doing nothing?
Same here but when it comes to running a hoe it would take me forever to get back in the swing of things. These guys can knock a job out quick...... WHEN THEY WORK. This will be the only hired worker on the garage.Now you know why I do EVERYTHING myself. It usually turns out better than most of the work I've paid for.
I could have gotten a better one but the guy doing it is an ex Marine (door knocker in Iraq) that's seen more than one should. Paying my respect I guess you could call it, good guy just bites off more than he can chew at times.You need a better excavator.
I wanted to do that but my bud is pretty busy as well and didn't want to put it on him.I rented one and stuck my buddy on it
Get in the thing and figure it out, at this point, you could probably figure it out faster. ... Course that's water under the bridge now!I could have gotten a better one but the guy doing it is an ex Marine (door knocker in Iraq) that's seen more than one should. Paying my respect I guess you could call it, good guy just bites off more than he can chew at times.
