Big day today. Made another fitting for the `cuda. It takes 100's of times longer to get this stuff ordered/shipped. than to do the actual work. I really miss driving within an hour of home, to get ANYTHING!
You must have been in the military.....I bought an upper ball-joint socket, and we spent a hour on the lathe and mill...making it into a tool I needed for one use.
Cool, I will post it for sure, when the time comes. That's a ways away yet though. Although I will be working in the cabin space next to get the final positioning worked out for the dash frame mounts and steering wheel assembly mount point, and the rectangular tunnel for the heat/ac, stereo/console/shift/parking brake assemblies all to mount to. Also sealing off the trunk area totally from the cabin for safety with the gas tank being over the axle space in the trunk. Once that's all worked out and the metal fab finished there are only a couple of other things before I can load some epoxy primer onto everything and begin filler/bodywork and getting the gaps and panel alignment worked out.Trust me, the thought has crossed my mind. I want to see the audi dash setup once it is up and running.
Don't know about the adjusters but I just did the same thing with the fender bolt on my 67. Decided to slice the top open and slide a bolt with a large captured washer into the space and re-weld the top closed. Now that bolt cant escape and it's long enough to accept spacers for adjusting the fender height.Started working on a few things this weekend. First was to clean up this fender bolt, or rather lack of it.
I also decided to pull the headlights and clean up behind them. I'm going to order some new adjusters for the headlights, as the old toast. Also are these old adjusters together right? I seem to remember them threading in from the other way on the last car I had.
Looking good man, the details count..Today I worked on the front and rear letters. I also worked on the rear panels.
View attachment 367803 View attachment 367804 View attachment 367805
