The Cometic gaskets showed up last week. Laid them on the block, checked fit at the cylinders. At approximately the 11 oclock position they come flush with the cylinder, but not hanging over. This is at the flat surface area of the head. At the chamber area the gasket is well back from the cylinders so they went in and everything went back together. A different look now without that big Indy intake and Eddies stacked on top.
The port match at the heads / intake was a dead match, didn't need to do any grinding or adding epoxy. On top of the Super Victor sits an AED 1050 Dominator with a 1/2" wood spacer under to keep the heat away. The coil was previously under the dash and now is relocated to near the distributor, which eliminated a 3' coil wire.
There was no difference in height from the Indy/Eddie set up. The carb won't be sealed to the hood this weekend. Will do something up nice along with a fibreglass hood for next season. Jets and air bleeds have been changed up to the same as what Wookie is running in his custom built AED 1050, (thanks Wooks). At mid range it seems to be over fuelling, although it starts, idles and its instant when you stab it. Wookie says not to worry, his acts exactly the same. Sure would be nice if I installed his MPH and ET along with his carb specs!
Had to drill and screw the rims as well. Last race day I marked the tires at the stem and in 2 passes the marks had moved over to the spoke, about 3". One side had moved a little more than the other.
Got things all back together on the Plymouth and time to spare so decided to try and salvage the glass bumper. Have added wood along the entire top lip, studs at each end for corner braces, a centre support and additional glass in other areas that were flimsy. Also glassed in some plywood blocks with studs for bumper brackets. I made the brackets out of 2" X 1/8" flat. 8.5 lbs so far including brackets. The big job starts when I tackle the other side.. If I can make something out of it and it looks acceptable I'll try to use it.
I picked this 36" 11,000 CFM fan from Princess Auto for 69 Bucks, taxes included.. They had a sidewalk sale on and gave an additional 75% off of the sale price. Crazy.. Will be perfect for those hot days at the track to cool the MW.
Looking for a new personal best this weekend!
