- 11:09 AM
- Oct 16, 2014
- Salisbury, Vermont
Looking very nice in there!!
Grin & bear it. Looks good.These 2 pictures show the detail a bit better. Oh yeah and she already covered a huge amount of it with a rug???I really don't get it...View attachment 525913 View attachment 525914
Appreciate the kind words but after seeing your work there's no doubt in my mind that your quite capable of pulling off whatever you set your mind to.I am always so impressed with the work you do. Like you, I try to do just about everything, but I have such limited time now I find I can't. I also don't know that I have the mad skills you have, able to tackle finish carpentry, rough carpentry, mechanical work, painting, fabricating, etc. Yes, I tackle some of that stuff, but not to your level.
RESPECT!
LeBlond very high quality. I have to ask you, how in the name of God did you move that by yourself. I figured you were a big boy when i seen those 10-12foot sheetrock boards you put up by yourself but a lathe that big LOLWell I'm finally getting back to the garage now that the renovation and the kids sports are done... problem now is it rains every chance I have to work on it.
Today I anchored down all of the mounting brackets to the concrete piers and stood 2 poles. It was getting really late and the impact echoed all threw the valley, didn't want to tick off any neighbor's so I packed it in. Supposed to rain tomorrow but I'll do whatever I can with any decent weather that I get.
Incase anybody missed this in my other thread I brang home a new toy and had a blast moving it by myself. 13ft long LeBlond lathe.. big enough to put your rear end and then some in it.
Steve I think he has a 'Gator' type 4-whl stashed there also; so that begs the question of what the floor looks like from dragging that behemoth?LeBlond very high quality. I have to ask you, how in the name of God did you move that by yourself. I figured you were a big boy when i seen those 10-12foot sheetrock boards you put up by yourself but a lathe that big LOL
Having a dad who's dragged home machines all of his life you learn that anything can be moved with enough leverage and or rolls. When it showed up here my dad had already lagged it down to 3X6 white oak beams so I just jacked it up and slid 4" wooden rolls (fence post) under it. From there you just throw a soft board on the floor (poplar) to bite into with the spud bar and go to down. It also had to be spun around as well but it was all done with a bar, wooden rolls and a floor jack.LeBlond very high quality. I have to ask you, how in the name of God did you move that by yourself. I figured you were a big boy when i seen those 10-12foot sheetrock boards you put up by yourself but a lathe that big LOL
220V 3 phase, we're just about done with the phase converter and I wired the garage knowing I'd be adding a 3rd leg so it's all good. Conveniently enough we were doing some major cleaning at work and I inherited some old open motors (unsafe in our environment), the phase converter will be using a 20hp motor.A nice lathe indeed. Does it have a 220volt motor? Or do you have three phase power?
I had to make a phase converter and add a transformer to run my 440 volt three phase lathe.
I have a 4wd Can Am and yes I tried it, it burnt the tires and didn't budge it an inch then I ripped the bumper off trying to tug on It! Wish I wouldn't have even fired it up.. something else to fix now!Steve I think he has a 'Gator' type 4-whl stashed there also; so that begs the question of what the floor looks like from dragging that behemoth?
I honestly haven't even touched it, with my dad being retired he has been tinkering with it and has it running. He's using a small maybe 1/4hp pony motor with a loose belt to get it up to speed before kicking it in. I'm not so sure how well I like the belt being used as a clutch but hey if it only eats a belt a year versus putting a motor big enough to start that 20hp then so be it because it would take a stout motor. I've got a 3 phase magnetic contactor that I'll use to kick it in via buttons.Thanks for that--It sounds like you have a good handle on your need.
For those that may want to know--A "rotary converter" is the way to go. Your 20hp motor will do you well to feed that big lathe what it needs.
BTW how will you start the 20hp motor/three phase generator? Just asking to see if my way was too off the wall?
I honestly haven't even touched it, with my dad being retired he has been tinkering with it and has it running. He's using a small maybe 1/4hp pony motor with a loose belt to get it up to speed before kicking it in. I'm not so sure how well I like the belt being used as a clutch but hey if it only eats a belt a year versus putting a motor big enough to start that 20hp then so be it because it would take a stout motor. I've got a 3 phase magnetic contactor that I'll use to kick it in via buttons.![]()
Not at all expesive, I think dad has 2 capacitors invested and a couple old motors. If you want cheap I've seen people just wrap a rope around the shaft and give it a rip then throw the power to it, works perfectly fine.In my case, I use a static converter. to start the generating motor.
They use a capacitor to get the motor running. This gets past the need for belts and clutches to get your generator motor up to speed.
Please follow up with this.--It also could be helpful to others reading.
Three-phase equipment is cheap and a bargain because buyers can be put off for the questions about making it run at home. It's not tough or a high expense in the big picture.
