PP1RT
Arent the unit heaters somewhat the same? Flame is blown into a tube and exhausted to the outdoors. Instead of radiating air is blown across the tubes that is curled up inside the heating unit?I like the idea of these but everybody I talk to says because they blow threw a tube then exhaust they aren't as effecient as a unit heater. Doesn't mean they'r not great but my primary concern is fuel usage, I'm looking at units that are 93% effecient.
The exhaust temp needs to be a certain temp level to eliminate condensation.
Radiant tubes have a much larger surface area to absorb heat.
Just thinking out loud. Seems to be no cut and dry perfect answer...
