- 10:37 PM
- May 14, 2011
- On the Ridge, TN
Got one coming from Summit, thanks.Moroso 41060.
A piece of 1 1/2" od thin wall pipe with a plug in it should work. The seal should hold it in place.
For no longer than you will be running it if the seal extends beyond the shaft just tape it off.
I'm still trying to resolve this theory of yours, though - if it didn't do it when I had the rear axle off the ground, chances
are it's not going to do it with the driveshaft out either, is it?
