- 12:05 AM
- Jan 29, 2018
- Midland Ontario, Canada
A bit more careful wiggling and prying.
Original signal plate apart, ready to clip the wires and clean the original base plate for reuse.
Wires clipped.
Make sure the contact wires are the correct length compared to the old and if need be carefully bend them for even pressure / contact on the base plate.
Dielectric grease on the contacts.
Squeezing the two plates together at the shaft and testing for continuity. Turn to left and right postions and check the green pair and the brown pairs for zero ohms in each of the positions (that is to say one pair only has continuity in each direction)
A bit of white grease in the signal shaft hole.
Signal plate in place and bearing / plate retainer going into place.
Wires clipped.
