themechanic
Oklahoma is OK
- 10:50 AM
- Nov 11, 2012
- Moore, Oklahoma
Whenever I washed the car I had wet floors. I had a badly scratched original windshield that I had replaced with new glass and gasket. The installer used calk inside the gasket and all around the metal surface where the gasket would sit. However, I still got wet floors after a wash.
So, I did some trouble shooting. The wiper pivot seals look new (replaced by the previous owner) and do not leak. When I put water in the cowl vent it drains rapidly outside the car just behind the tires; I assume this is by design. Finally, both the driver and passenger floors get wet rather quickly when I put water just below the windshield gasket where it meets the cowl. The water can be seen inside the car running down the metal where the kick panel cover mounts, then it pools on the floor.
When I had the windshield replaced I noticed what appeared to be drain holes along where the glass meets the metal (ie the trough where the molding clips go).
1. Are these really drain holes?
2. If so, where are they supposed to drain water away from the windshield?
