mopar 3 B
His stock wheel well will not allow that wide a tire.THis is wrong. A wider tire has a larger contact patch. The extra traction also means more drag.
Its going to be really hard to justify that or anything larger with only the 318 to power it.A ‘74 Satellite has narrow wheel wells?!
LMAO, no way! Get atta here!
I’ve seen 275/60/15’s as almost common. Ya gotta be able to fit bigger *I think?*
Regardless....
Back to the MPG issue at hand.....
How about a pic of the rear end? I have my doubts that it is a dana whereas I bet it's probably 8 3/4.
How wide of tires are you running?[/QUOTE
I can remember 4 mpg but gas was $0.35 per gal. . Cost a whole $5 to fill the tank.
Mopar 3B...that is the mystery in a nutshell. The guy couldnt make up his mind between having a numbers perfect satellite or a hot little roadrunner clone. The paint job and alloy rims are worth more than the 1500 hundred I payed for it.Its going to be really hard to justify that or anything larger with only the 318 to power it.
8 1/4 rear end is oval with 10 bolts
I never suggested it nor would I suggest it. Thanks you.Its going to be really hard to justify that or anything larger with only the 318 to power it.
lol, I could raise a family in those wheel wellsHis stock wheel well will not allow that wide a tire.
If you're looking for milage you have to get into the tuning. These cars don't tune themselves like a modern car so you need to dig into how to set and control the timing curve, and then how to tune the carburetor. You should have the vacuum advance connected, and you should know exactly what the initial timing is, and the centrifugal amount and what rpm it starts and finishes at. Once that's set you can plug in the vacuum advance and set the carb. Chances are it will be lean which when combined with the timing you gives you the pinging. You will need the Edelbrock strip kit for that carb. Always do timing first, carb last.
