dsd1967
I'm putting a trunk floor into my belvedere and was trying to get the sheet metal to stick to the frame rail and can't seem to get enough heat into the frame rail before the punched sheet metal hole is filled with filler.
My welder is an older off brand "Century" 110v welder. I'm using .035 wire at the highest heat setting and matching the wire speed to get a good "sizzle". The hole in the pan is about .300 in diameter.
Should I switch back to a .023 wire with a high heat setting and fast wire speed
Should I back off the heat setting and slow down the wire speed on the .035
Any expert advice?
Any expert advice?
