- 4:16 AM
- May 14, 2011
- On the Ridge, TN
Could very well have been, Jim. That initial issue that occurred that day has proved to have been an isolated case and probably was due toGoing back through your posts, the problem surfaced upon hard acceleration & descending/stopping on a significant downgrade. No significant leaks & doesn’t burn oil. You seem like a guy that takes care of his stuff & wouldn’t be running it low on oil, whether it’s a 4 or 5 qt pan. The possibility of having a high volume pump with low capacity pan was previously mentioned. I’m nowhere near any kind of expert on this stuff, but could it be related to your pickup. You said your 440 is an early 70’s. The 699 pan is used to convert a 440 into a A-body to provide for suspension clearance issues. As previously mentioned my 402 pan does not have the recessed area as the 699 in your photos. With the different pan configurations is a different pickup required to seat at the proper level in the sump.....Jim
low oil level so once I added more, it hasn't occurred again - but then, it never occurred before that day, either.
I'm a gauge watcher by nature, I'd have seen trouble if it had. Since I added some oil and the event never reoccurred, I chalked it up to low oil level.
It should be noted here that my own driveway (well, it's over a 1/4 mile long, I should call it a road I suppose) is even steeper than that street in town
where the problem first became evident and I've never experienced an issue either going up it or down, always in first gear/higher RPM.
From what I can garner from all the information on the 440Source site, with all the "stock" depth pans, whether my 699 (which is the correct stock pan for
this engine) the 187 or even your 402, there's two pickups - one with a curved tube to clear internal baffles and a straight tube one for those pans without
baffles.
The above pertains to stock 3/8" diameter pickups, of course.
Given all that, I wish I could tell you what pickup is in this engine, but I've not had the pan off it since it arrived.
Further, the pan is quite battered, lending thought to perhaps even the pickup being bent as well. The sump part of the pan has certainly been pushed up
a small amount, so it no doubt got closer to the pickup.
Thing is, I'm having a BLAST playing with all this stuff again, I really am.
Considering how many times in the last half dozen years I've been told by docs to "get my affairs in order", to just be here still to
mess with cars one more time is a blessing I can't find words to describe.
Heck, I'm still cracking up about what I did just last night to it. Drain it, put the genie back in the bottle (take out one quart volume
by pouring out of a BIG outlet on the drain pan into the little bitty neck of an oil bottle), pour the rest back in the engine.
THEN hacking off enough dipstick tube to make the dipstick read correctly.
I mean, that's goofy stuff to be doing - and it's tickling me to death to still be here to do it.
I am VERY grateful to folks here like you, Jim, for helping me along with this stuff.
