- 5:25 AM
- May 14, 2011
- On the Ridge, TN
We were off to town this evening for the local cruise-in and once it was time to go, off we went.
We came to a fairly steep downhill stop sign and the OIL light came on briefly on the dash. I took a quick glance down to the electric aftermarket gauge and sure enough, suddenly I had no freaking oil pressure!
I carefully pulled away from the intersection to level ground, popped it out of gear to take the load off the engine and oil pressure returned quickly.
Thinking not much of it, we again set off for home again.
When we got to the 4-lane, I did my traditional "beat on it" through the first three gears, shifting at about 5200RPM, which the car did just fine. Let it into 4th easy and went the rest of the way to the next turn (about a 1/4 mile or so) which is another slight downhill incline, coasting down to make the stop and turn - and the thing again went to zero oil pressure, this time with some accompanying staccato rattling from the engine!
Popped it into neutral again and waited a couple seconds and sure enough, the oil pressure returned again and she quietened down.
We basically snuck back home at that point, thankfully with no further incident.
Now, I know the engine probably pumped all the oil into the top end on the 4 lane, right?
Makes me want to put a bigger pan on the thing for sure - or at least, give her an extra quart in the "699" pan on her now.
You know, that original pan I have that has seen some dents and such....
Is all this just simply not enough oil in the engine or do I need to worry about the pump, pickup, etc.? First time it's pulled this nonsense.
PS Sorry, I assume everyone knows what I have. The engine is a low mile, rebuilt early 70's 440 that actually runs pretty darn good. Has the purpleshaft 484 cam in it. Nothing fancy, typically sees 30 psi oil pressure when hot and idling, goes up over 60 when up in the RPM's.
