- 2:48 PM
- Mar 28, 2014
- South Louisiana
70 Roadrunner, V-code, 3/8ths" fuel line.
Current setup is hard fuel line from tank to 3/8ths rubber to fuel filter to 3/8ths rubber to hard line into fuel pump. Hard line out of pump to rubber line into vapor separator. Rubber return line from vapor separator back to tank. Rubber line to hard line to carb lines.
The Promax lower fuel line is designed to attach directly into the fuel pump. It incorporates a 40 micron fuel filter. That assembly attaches to the Promax carb lines.
?? If I bypass my vapor separator (remove it) what do I do with the return line? Plug it?
Also should I be able to eliminate the inline fuel filter before the fuel pump since the Promax lower fuel line has a 40 micron inline reusable fuel filter?
