- 1:48 AM
- Jun 12, 2012
- NZ - just short of the South Pole
You're getting the hang of this wiring stuff now.
The frame was part of the design authentics? Inserts into wet concrete and just setting it on the legs would have been less time consuming. There is enough rebar in it to support any reasonable load and with 6000 psi mix that may have been over kill.
Next time use a vibrating hand sander. Pad to form will work those naste bubbles right out.
That's awesome!! How is the faucet mounted.
I'm watching, can't wait to see the finished project.It's not mounted yet . . . have not got to that part of the build . . . quite yet . . .
I think washing up in that tub will prove to be a pain in the *** in a very short time. The angle is not user-friendly. Otherwise I love it. Not my style but very cool none-the-less.
Not sure about your area but will the tub pass code without an overflow drain?
