Nice view, Dennis. What's next? Intermittent wipers?View attachment 711390 100 miles today. PCH. Fuel still above 3/4? RPM’s are 2035 @72 MPH in 5th. Was 2150 @ 70 with previous TKO so lower. Rolls on real nice, got on it a little. Spark advance kissed 29 at highway cruise. No hiccups. Restarts. All good.
Love those cruising rpm's, pretty much perfect for a mild BB.View attachment 711390 100 miles today. PCH. Fuel still above 3/4? RPM’s are 2035 @72 MPH in 5th. Was 2150 @ 70 with previous TKO so lower. Rolls on real nice, got on it a little. Spark advance kissed 29 at highway cruise. No hiccups. Restarts. All good.
Not sure I understand. The spark advance was at 29 degrees or the advance was at some unknown number that allowed you 29 miles per gallon ? I'm guessing 29 mpg because at cruise conditions, the engine needs a LOT more timing because the air and fuel molecules are not packed as tight as they are under wide open throttle.View attachment 711390 100 miles today. PCH. Spark advance kissed 29 at highway cruise. No hiccups. Restarts. All good.
I was wondering too. Assuming 34* int + mech, another 29* vacuum advances to 63*. Could happen cruising 55 mph downhill.Not sure I understand. The spark advance was at 29 degrees or the advance was at some unknown number that allowed you 29 miles per gallon ? I'm guessing 29 mpg because at cruise conditions, the engine needs a LOT more timing because the air and fuel molecules are not packed as tight as they are under wide open throttle.
Either way, it is great that this is working out for you.
3:54.What Gear Ratio are you running Dennis?
I have 3:23's now. Might go 3:73 or 3:553:54 Dana.
Ahhh...Bragging about the Dana again like you are ROYALTY or something. Next thing is you'll say your car is an original 440, 4 speed car and that you daily drive it.3:54 Dana.
Edit.3:54.
Rough measurements, but looks ok by about an inch. That is a drop down dime store air cleaner. View attachment 646345 View attachment 646344
