Yes! There are 2 contacts burnt beyond salvage .Did you try opening the switch and repairing it? Might not be that difficult, and probably easier than finding a replacement.
Dimensions are in the link I provided above....if that helps - there are different size bodies for those switches. Square shaft for the knobs, and usually plenty of length on the shaft to accommodate a steel mounting plate.Thanks for all the input ! Here's the $1000 question...... What do either of the switches in the links provided look like with the knob and plate removed??? It needs to match the pic on the 3rd row left side. (1st post)
Look at the pic below - it needs to mount to that steel plate and the shaft needs to fit that black arm on the bottom of the pic (thats connected to a peddle.)
View attachment 719666 View attachment 719672
My screw holes for mounting - 30/31 ? mm shaft size 5 ? mm This seems to be a common thing - everything I find is BIGGER. Just got off the phone w shopequipmentparts again way BIGDimensions are in the link I provided above....if that helps - there are different size bodies for those switches. Square shaft for the knobs, and usually plenty of length on the shaft to accommodate a steel mounting plate.
Really?? Not trying to be a smart azz here....They are identical. If you rotary part is different, just loosen the set screw and remove it.
A switch is a switch, just because the actuator is different doesn't mean anything. The switch gets installed onto the chassis, and then an actuator is attached to it.Really?? Not trying to be a smart azz here....
