So curious, what does the world believe is the correct cluster for 68 'X? I pulled from my 68 'X a 120 MPH speedo cluster with no tach(see the middle cluster in the pix). For some reason I don't think this 68 cluster was OEM, but not real sure. I pulled from my '69 'X the one on the right with the tach and 150 MPH speedo with single/two digit (no zero) speedo numbers. The one on the left is a donor 150 MPH cluster I grabbed at a swap.
What speedos had the full 2/3 digit speed numbers?
My car has an October 6th build date and came with the early speedometer. Not sure if there is an exact date for the switch over but I am sure they used up any stock they had first.
Dang rust hides everywhere but that looks very fixable. My roof was all rusted out at the c pillar from a shoddy re-vinyl.
When was your car last painted?
Correct!So that must be Oct 67....I'm thinking by Oct 68 they were building 69's
Correct!
So your car was originally yellow? I didn't see the fender tag but saw the read out given and spots of yellow showing.
Yep, I had problems in all the same places.
You can see the filler at the top of the door post.
Support structure under the sail panels needed major repair. Ended up scrapping the roof skin.
Correct, it was originally yellow. After much debate we made the decision to stick with yellow for the repaint. Although I will likely use a more modern yellow that pops. The interior was green. I had to come to terms with keeping it original and doing something that I like. So bright yellow ish and original green interior.
hang doors on that thing.... make them perfectly parallel / level with the rocker.
So is this a standard procedure to have to cut apart AMD quarters to fit the rear window corner and the gutter flange?
View attachment 951463 View attachment 951464
