Brian DePouli
While messing with the wiper motor I noticed the vacuum tubes we're poorly run and interfering with the under dash wiper arms. So fixed this and while having that out I replaced the bulbs in the control panel as well.
Brian, I didn’t know if your car is like mine. My car has a hole in the fender well where the shorter battery hook hooks into.
It sounds like you are going through the same process I am. Even though you are finding problems you are still getting things fixed too. Looks to me like you are doing a great job.
Sure,AH HA!!! Thanks!! Mine was all rotted out in that area so we had a patch made. I suspected I might be missing a hole. Any chance you can get me a bit more dimensions?. Looks to be about 1" behind the hose for the harness clip and maybe a 1/4" diameter hole. Probably not critical, but ..
It only took me a few hits to finally realize to wrap a small towel around it.....You can also use a tennis ball....Largely unsuccessful day.
I did put the new wiper motor partially in and it works, but didn't do the under dash work.
The water pump was definitely a problem.
Unfortunately new water pump leaks profusely. Perhaps the gasket slipped. Will try again tomorrow, but very disappointed as it was a LOT of work for no success.
What I did manage to do well was bleed copiously from my head after I hit it on the hood catch when I was wrestling with the water pump/AC compressor as it started to crack lighting and poured buckets as my wife yelled at me as she poorly attempted to help
The gasket could have squirmed.....How does the housing mating surface look?Largely unsuccessful day.
The far left goes on the bumper the 2 bigger ones go on the valence....The 4 smaller ones I just cant recall at the moment.Actually disappointed with this kit...it's going back... I don't think I got the rear valence license plate bumpers (or just one at the far left) looking at other kits online and going out to my car I feel like this kit is not complete.
That said I still need to know where these go
https://shop.advanceautoparts.com/p...VirbACh1r6wKwEAQYASABEgJuyfD_BwE&gclsrc=aw.ds
Let it sit 24hrs at least before firing up.....
Do those 2 have numbers on the top?.....IIRC its been awhile but the far left goes on the bumper and I though the valence had 2 taller ones similar to those two.....It's a repro valence and the two bigger ones are too small for the holes in the valence. the far left one fits perfectly though?
no numbers, I ordered a different kit (at least per the photo) from a different supplier so we will see, photo below of the newly ordered kit from their website. same part number as YO but a lot more piecesDo those 2 have numbers on the top?.....IIRC its been awhile but the far left goes on the bumper and I though the valence had 2 taller ones similar to those two.....
27 versus 23.....imagine that...no numbers, I ordered a different kit (at least per the photo) from a different supplier so we will see, photo below of the newly ordered kit from their website. same part number as YO but a lot more pieces
