You mentioned Hagarty, problem solved..... they will easily shell out enough to fix the dent, and paint the entire side to match. Find someone who can handle it
if you have to search the planet for a super talented pdr artist.......... he aint working cheap, he may or may not achieve the desired result, and he may not even exist....... if you're gonna spend time, energy, and money; just give it a proper dent repair.
remember.... these pdr guys are fixing late model stuff on car lots, and the metal they are used to working with is pretty flimsy.... most of them are hacks, I've seen it all
Hagerty covered the dent and subsequent necessary refinishing of both quarters and roof.She looks GREAT !!!!! Glad to see her back. So, did Haggerty cover all that work? Was it a supplemental?
Thanks. Yeah, I pretty much knew when the dent was "oil canning" on me that the creaselmao @ all that pdr nonsense![]()
congrats ED.... glad it worked out in your favor!
Yes sir, indeed. I'm big on singing praises - or yelling condemnation when earned.Looks like the shop did right by you and went above and beyond. Be sure to give them positive reviews and forward their good name to others. Good honest bodywork folks (like @eldubb440 above) are hard to find.
Scorecard
Hagerty: A+ all the way, handled everything perfectly
I have absolutely nothing bad to report on them. They handled everything efficiently and followed up as things progressed.Good to see that Hagerty handled it well. Quite a few of us use them ( me included) !!![]()
Thanky kindly.So glad to see she's back home where she belongs. Sounds like you got a real winner of a shop who knows their stuff on these old cars.
Why don't you bring it over to them to remove? If you damage the clearcoat while doing it, they're off the hook.Thanky kindly.
Yeah, the dude kept saying "she's gonna get the love she needs here" over and over.
I don't want to piss on their parade, but there's some leftover residual, well, residue left at the base of the roof
on all four corners. It almost looks like collected small pools of clearcoat? Kinda like the acrylic mama used to
put on the kitchen floor, if that makes sense.
I got to get something a bit stronger than what I have to get that off.
Thinking polishing compound maybe?
Oh no, I'm done bringing it over to them for a while. Or ever.Why don't you bring it over to them to remove? If you damage the clearcoat while doing it, they're off the hook.
Glad to hear it all worked out great for you Ed!!UPDATE 6/28/19:
She's baaaaaaack!
Wound up, she needed a little more attention than just the self-inflicted dent!She's home safe and sound, after me getting heat prostration and having to outrun a couple of wicked thunderstorms.
On both rockers under the rear of the door openings, rust had stirred up and holes were present, covered only by the previous owners' quick fiberglass patches.
That got cleaned out of there and new metal patches installed.
The roof "lead" seam on drivers' side was a mess and they wound up melting out all the original lead on BOTH sides, then fabricating metal to repair those areas as well.
Finally, although Hagerty had only approved a "blending of the roof and both quarters", the body shop wound up basically repainting the entire car from behind the doors as well as the roof!
Color matching proved exact - even though I had the original Sherwin-Williams codes for the car and she'd never been outside garages much, the shop usually don't use that brand.
Well - I suspect they tried to color match with their own stuff, then found someone local who DID have S-W and blended up exact match once their attempt failed. The car wound up getting the exact same S-W paint as original.
No matter - the net result is, she looks a TON better. Very happy!
Thank God...
Thank ya brother!Glad to hear it all worked out great for you Ed!!
Thanks. Yes sir, that IS the plan.Looks sharp!! I'm glad you had a painless experience. Now go drive the wheels off.![]()
Thanky kindly.
I don't think that's what it is.Could be where they blended the clear coat. Could be adhesion promoter. In any case, if you try to buff it off, it will leave a sharper line where the two meet. It will be more visible. They should have found a line or edge to stop instead of blending the clear coat.
I would bite the bullet and stop by their shop with it and show them what you see. Now's the time to fix it, not later.
Hard to explain exactly - more like random splotches of what looks like a milky/hazy, very thin plasticky substance.
I'll see if I can get the camera to capture one...
EDIT: Now that I look at it up close, it almost looks like they tried to shoot some clear over the old paint in that area and it didn't adhere?
\View attachment 791507
Yes. As previously described, the original (11 years old!) paint job that was half-assed by the previous owner was base/clear, Sherwin-Williams paint.Is it a base coat/ clear coat paint job?
