Curiousyellow71
TN mopar is the fly cutting you mentioned what just came with the pistons or are theycut for bigger valves. If I remember right I think 2355 is the forged six pack piston for 2.08 valves... future head upgrades may make your clearances unsuitable if it has bigger valves. 2355 piston valve reliefs are not too deep. My guess from experience things are going to get tight at .550 lift if you have had any head surfaces machined you may not be able to run that much. Not much more to add then what had already been said you have had sound advice. But when you push clearances at .080 on the intake and .1 on the exhaust the larger duration cam will make your valve clearance go away fast. One option is to use a cam ground with a centerline that moves the valves away from the piston as the valve is shutting and run more duration.
