I may be over-thinking it. It wouldn't be the first time. EACH time before I embark on a new task, I ask questions, do research, make lists....It is the unknown that has me thinking that is a difficult job.
This will be my first structural replacement job. I've done floor pans, quarter skins, roof skins and other stuff but the structural members were not disturbed. What concerns me is being off a little here, a little there and then none of the sheet metal lines up and gaps right.
I have a FSM that shows many measurements but I'd expect to see more. For instance, the RH rail is currently compressed a bit rearward. It can  be pulled forward  but even when it measures right, it could be further off the floor than the other side if it is still bent upward. Where is the reference measurement for that? The fender to rocker gap may be a guide as to the rail being close to "spec" but these fenders do flex a lot.
I can do criss cross measurements to get the front square. It could be slightly corkscrewed though.
This is why when I see guys post pictures of their cars with the entire rear of the car missing behind the C pillars, I wonder how the heck they get it all back together with good panel gaps and proper fitment.
1) if you replace the rail, all the way back to the torsion member, it is no longer compressed a bit rearward
2) mock up all front sheet meta (doors, fenders, hood, lower valence, grille and lights ) with a minimal amount of tack welds and screws holding your repair together
3) adjust your repair to achieve near perfect alignment..... "bring your repair (rail and inner fender) to the outer panels"
4) yes, fenders flex, but when bolted all the way around they get stiff and find a happy place
5) the hood aligned with the cowl will dictate the front being square..... hood stops on top of radiator support should be equal
6)the more you mock up, the easier it is.......... it all only fits one way
7)break it down and weld it up
yes.... everyone over thinks it
the outer metal dictates everything, starting with the doors and hood
the nice thing about collision work is, you can't really make it any worse....... and you'll be surprised how easily it all falls in line
you won't be happy paying someone else to have the fun
