- 4:34 AM
- Mar 28, 2014
- South Louisiana
When I get a WEDGE head stroker motor built, I don't want to have to worry about pushing it too far. My target HP is 600 and 650 torque. I am definitely going to have a 3x2 intake setup, starting with Promax modded Holley carbs, and the dual plane Edelbrock/Chrysler aluminum 6bbl intake, with the Indy ModMan 6bbl as an option for a single plane intake. If I go with an aftermarket block, I would probably ditch the factory 6bbl intake and go to the ModMan, and even consider the TrickFlow 270 MaxWedge ports vs the 240s.
From what I have read, that is towards the upper limit of the factory block. I would like the option of adding a 100-200 HP spacer plate based Nitrous Oxide system, to have that headroom should I want to step up who I can compete against in a heads up grudge race. Then again, I may find that 600HP/650TQ is as much power that I can handle...
I am keeping my current 71 440 heavy rods forged crank engine intact, so I'd have to buy another block anyway, and unless I bought aftermarket, I'd have to trust that the factory block the builder used was a good block.
Given the cost of the build, and the cost of iron aftermarket blocks, the cost of a girdle and machining aluminum caps, I don't have a problem given all of the costs involved, to just go all out and get an Indy aluminum Maxx block.
Is anyone using a water jacketed Indy Maxx aluminum block in a stroker wedge configuration as a STREET/strip car?
I may go to the track twice a month once it's all said and done, but now I only run at the track a few times a year.
Any feedback is welcome, including opinions/experience on what a 600HP/650 TQ engine is like driving and racing in a B-Body on the street and occasionally at the 1320.
