 - 4:30 PM
 - Apr 13, 2012
 - Granite Bay CA
I pulled the valves out and took a look at the ports.
That ring below the seat..... My understanding is that anything sharp that is in the path of flow is a restriction.
Notice the irregular shape of the ring on this port above.
Intake port below. I see a bump to the left of the valve guide. I'm curious if the guide boss needs any smoothing since the flow comes in from behind it and not toward it.
I apologize for the blue shaded light but I needed some light for this picture:
I am running on common sense here since I have no experience with this. It seems to me that when porting, you need to look at which direction the flow is going. For exhaust, I think that smoothing out around the valve guide boss makes sense along with eliminating that ring below the valve seat.
I am using an air powered die grinder that I already had here. I may need to go get more bits though. On each head there 4 exhaust and 4 intake ports with inlets and outlets to grind on
